Activity Forums Maxon Cinema 4D Why rainbow sparks when moving points?
  • Why rainbow sparks when moving points?
    Posted by Tom on June 28, 2007 at 2:34 pm
    Can anyone help me shut this “feature” off?
    When I am modeling with spines/points, every time I move a point,
    I get these rainbow looking lines that shoot out all over the place
    (like Timothy Leary’s version of normals).
    Thanks in advance,
    TH
    Tom replied 19 years, 2 months ago 2 Members · 6 Replies
  • Adam Trachtenberg
    June 28, 2007 at 4:50 pm
    Sounds like an OpenGL problem. Do you have the latest drivers for your card? Does it still happen if you disable OGL in preferences?
  • Tom
    June 28, 2007 at 11:35 pm
    Thanks Adam, spot on!
    When I changed to Software Shading, no more sparks.
    What is the advantage of OpenGL over Software-Shading?
    Cheers,
    TH
  • Adam Trachtenberg
    June 29, 2007 at 3:49 pm
    OpenGL will give you much livelier viewport performcane, provided you have a reasonably modern video card. The new (v10) Extended OpenGL will also provide a much better preview of the rendered image, with support for bump/normal maps, shadows, improved transparency, etc.
    What video card are you using?
  • Tom
    June 29, 2007 at 4:42 pm
    Here is my system:
    OS: WinXP Pro SP2
    Video Card: GeForce8600GTS 256MB, Driver up-to-date.
    CPU: Intel Dual core @ 1.86Ghz
    Ram: 2GB
    I believe (hope) this system is adequate enough and it’s my settings
    that are the issue.
    Can I actually update myself to Extended OpenGL (v10)?
    [not sure what I actually have now..]
    Cheers / TH
  • Adam Trachtenberg
    June 30, 2007 at 5:54 pm
    [Tom Headle] “Here is my system:
    OS: WinXP Pro SP2
    Ram: 2GB
    that are the issue.
    [not sure what I actually have now..]”
    Hi Tom,
    Your system should be more than ample to run OGL and EOGL (which is just an option in v10’s View>Properties. You can confirm EOGL compatibility by checking the general preferences>viewport settings. In there you’ll find a button called “Show OpenGL Capabilities.” Press the button and if all is well the bottom line in the resulting dialogue should say, “Your graphics card has all necessary extensions for Enhanced OpenGL”.
    If you continue to have problems you should probably give Maxon’s tech support a ring. It could be a hardware problem or….?
  • Tom
    July 3, 2007 at 4:41 pm
    FYI:
    I found something here that works, although I don’t understand why:
    https://forums.nvidia.com/index.php?showtopic=38802
    When I uncheck this, all is well:
    [ ] Use OGL Points for Handles(faster if supported)
