Why no razor blades on simple interface audio editors?
Aloha all!
I’m frustrated. I have a recurring project in which I record a two hour radio show then isolate the DJ breaks.
What I want is an audio editor that works the same way an audio track in FCP or Premiere works. I want to look at the waveform, use the playhead to locate points, and use a razor blade to cut them.
Soundtrack and Audition both force you to create a multitrack session before enabling the razor blade or the split command. Why? I can highlight and delete in the simple view, why not razor blade?
Audition, as far as I can tell, doesn’t even have a razor, although I’ve only dabbled in that.
Is there a reason that powerful audio editing tools disable this basic functionality in their “easy” interface?
The difference between theory and reality is that, in theory, there is no difference between theory and reality.
