Activity › Forums › Apple Final Cut Pro › Why no ‘Create Optimized media’ option?
Tom Wolsky replied 14 years, 11 months ago 6 Members · 17 Replies
Hegedus Gyula
October 18, 2011 at 5:08 amThere are no separete render files in FCPX. It writes the new render-data in a database file. It is good because the connection will NEVER gone between the project clip and the render data. It is bad because you can’t reach the standalone render files like in FCP7.
James Bayliss-smith
October 18, 2011 at 7:05 amThanks but I still don’t really get this
[Hegedus Gyula] ” It is bad because you can’t reach the standalone render files like in FCP7.”
Why would one want to access the standalone render files?
James
Hegedus Gyula
October 18, 2011 at 7:43 amThe big change: “Current Settings” does not mean anymore the Sequence (here Project) settings.
In FCPX the current settings = RENDER SETTINGS (ProRes4444/422HQ/422/10bit Uncompressed).
For your question: sometime it would be easier to find a previous render file (for analyzing, sharing, reusing…etc) in the render folder, than hitting undo..undo…undo…etc.
All in all: the new render management is better than in FCP7 and FCPX is smart enough to NOT allow export an HDV master directly from FCPX.
Cheers,
gyula from Budapest
Tom Wolsky
October 18, 2011 at 10:37 amThis is not entirely true. While FCP does use a data base to keep track of the render files, the rendered media is in a folder attached to the project and can be dumped at any time. You can also trash renders from inside FCP.
All the best,
Tom
Class on Demand DVDs “Complete Training for FCP7,” “Basic Training for FCS” and “Final Cut Express Made Easy”
Coming in 2011 “Complete Training for FCPX” from Class on Demand
“Final Cut Pro X for iMovie and Final Cut Express Users” from Focal Press -
Tom Wolsky
October 18, 2011 at 11:37 amThat’s correct. A media file gets created in the Render folder. The media file is in ProRes.
When you export media with current settings you’re not exporting HDV. You’re exporting in the render format, which by default is ProRes.
All the best,
Tom
Hegedus Gyula
October 18, 2011 at 12:06 pmSorry Tom, I am not perfect in english. What does it mean “dumped”?
Because
in my Final Cut Projects folder there are the folders named after the projects 🙂
In those there are the CurrentVersion.fcpproject file and the Render Files folder.
In the Render Files folder there are three subfolder: High Quality Media, Peaks Data, Thumbnail Media. In each of them there are a lot crucifix named folder….
…and at the and: document files like this: Frame 48128 – 49151.So where can I find and how can I “dumped” the ProRes mov render files you mentioned above???
Thx,
gyula
Tom Wolsky
October 18, 2011 at 2:36 pmThe High Quality Media contains the ProRes data base. By dump I mean move to the the trash. Which actual files refer to which bits of the project I don’t have any way of knowing, but these files can be deleted at any time and FCP will rebuild them.
All the best,
Tom
