Activity Forums Apple Final Cut Pro Legacy Why no alpha on mov when it does have alpha?
  • Why no alpha on mov when it does have alpha?
    Posted by Kent Beeson on April 13, 2010 at 3:16 am
    Hi
    Doing an SD timeline…seq is Uncompressed 720×480, got a couple of motion text files I want to overlay on my video. So made a QT mov of the motion files, Pro Res 4444 ,alpha, SD. Brought them into timeline, but they won’t key, as if there’s no alpha channel. But on export I make sure there is. However, in FCP browser when I right click on the mov file for item properties, format and alpha it shows as “none/ignore.” Is this why it won’t key, What to do?
    K
    http://www.effectivevideo.net
    Kent Beeson replied 16 years, 4 months ago 3 Members · 4 Replies
  • Kent Beeson
    April 13, 2010 at 4:27 am
    Was told correctly by Tom W to turn on the Alpha in FCP by right clicking in the item properties tab and changing from none to straight or black or white, whichever I need and it works now…
    K
  • Bret Williams
    Click on that and choose straight or premultiply. Whichever you used.
  • Jim Mcnally
    April 13, 2010 at 4:30 am
    In motion do you have a background that you are exporting with the text? Make sure you have checkerboard under your text when exporting.
    Jim McNally
    The Commercial Factory
    http://www.commercialfactory.com
  • Kent Beeson
    April 13, 2010 at 4:32 am
    Yes, it has transparent BG…thanks for all replies, it’s fixed as per my second post above…
    K
