Activity Forums Blackmagic Design Why isn’t there a FCP Easy Setup for 720P30
  • Why isn’t there a FCP Easy Setup for 720P30
    Posted by Herb Sevush on April 22, 2008 at 11:14 pm
    I have a Blackmagic Decklink HDPro that I use with Final Cut Pro. I normally work with DVCPRO 720P60 varicam material and use the blackmagic Easy Setup provided. Now I’m doing a series that was shot in 720P30 – but there is no Easy Setup for it and seemingly no way to ingest thru the Blackmagic Card. I see there is an Easy Setup for 720P24 as well as 720P60, but nothing for 720P30 – why?
    Herb Sevush
    Zebra Productions
    Herb Sevush replied 18 years, 4 months ago 2 Members · 2 Replies
  • Del Chapple
    May 5, 2008 at 2:37 pm
    can you make your own easy setup in fcp. or does it not let you pick 720p 30?
    del
    you cant hear my inner voice scream… can you..?
  • Herb Sevush
    May 5, 2008 at 5:14 pm
    It turns out you can make an easy setup for DVCPRO 720P29.97 by modifying the 720P59.94 easy setup – but I was just curious as to why the omission from blackmagic – they had every other variation possible and 30FPS was an original option from Panasonic so it just seemed strange that they would omit this one setting.
    Herb Sevush
    Zebra Productions
