Activity Forums Creative Community Conversations Why isn’t FCPX syncing my multiclips!
  • Why isn’t FCPX syncing my multiclips!
    Posted by Aaron Weisblatt on September 4, 2013 at 5:56 pm
    When I attempt to make a multiclip, with the “use audio for sycronization” engaged, it is creating a multiclip with one clip lining up to the next in a linear timeline….I have not had this issue before – what is happening?
    thanks
    Aaron
    Aaron Weisblatt replied 13 years ago 3 Members · 7 Replies
  • 7 Replies
  • James Cude
    September 4, 2013 at 6:14 pm
    Is everything else set to automatic? Perhaps you are also syncing by timecode. Send a screenshot.
  • Aaron Weisblatt
    September 4, 2013 at 6:17 pm
    yes everything is set to automatic. I even increased the gain on the one clip that was from the internal microphone of the camera that was lower in volume than the other. but both clips are very well recorded
    so….I don’t think that should be an issue in the syncronization…ugh
  • Aaron Weisblatt
    September 4, 2013 at 6:44 pm
    ugh….still didnt work….
  • Ronny Courtens
    September 4, 2013 at 7:02 pm
    If this does not work you can use this workaround:
    R-click the multicam clip and select “Open in Angle Editor”. This will open the multicam clip in its own timeline. You will see both your clips one after the other on the same angle.
    Click the down-facing arrow on the angle and choose Add Angle from the menu. A new angle will be added under the existing one. Then drag the other clip in the angle down to the new angle, and from the dropdown menu choose “synchronize to monitoring angle”.
    This will synchronize both clips in both angles.
    Send feedback to Apple about this.
    – Ronny
    – Ronny
  • Ronny Courtens
    September 4, 2013 at 7:04 pm
    – Ronny
  • Ronny Courtens
    September 4, 2013 at 7:11 pm
    EDIT: In the Inspector > Info > Extended view you must go to Camera Angle and assign a unique Camera Angle (e.g. Angle 1, Angle 2…) for each clip. Then the clips should synch up in their respective angles. Sorry for the wrong information in my first reply.
    – Ronny
  • Aaron Weisblatt
    September 4, 2013 at 7:18 pm
    yea! it worked!
    Thanks you so much!
