Activity Forums VEGAS Pro Why is Vegas doubling file size when rendering?
  • Why is Vegas doubling file size when rendering?
    Posted by Maria Maronska on November 12, 2015 at 9:33 pm
    The original file was recorded using the following settings:
    Then it was rendered in Vegas (without any changes, just for testing) with output settings:
    Audio: 48 000 Hz; 16 Bit (MAC); Stereo; PCM
    Video: 25 fps; 1280×720 Progressive
    Pixel Aspect Ratio: 1,000
    The original AVI file size is 369 MB and the Vegas rendered file is 753 MB. Why the difference and how to make the rendered file smaller without losing original quality?
    Steve Rhoden replied 10 years, 9 months ago 3 Members · 2 Replies
  • John Rofrano
    November 13, 2015 at 12:22 am
    You didn’t say what codec or bit rate you used for the render but only thing that will change the file size is the bit rate. Increasing the bit rate increases the file size for a given codec.
    ~jr
    http://www.johnrofrano.com
    http://www.vasst.com
  • Steve Rhoden
    November 13, 2015 at 10:58 am
    But you haven’t mentioned what codec you rendered the final output in!
    The codec is the single most important issue where rendering to a smaller
    file size without much quality loss is concerned.
    Steve Rhoden (Cow Leader)
    Film Maker & VFX Artist.
    Owner of Filmex Creative Media.
    Samples of my Work and Company can be seen here:
    https://www.facebook.com/FilmexCreativeMedia
