Activity Forums Adobe After Effects Expressions Why is thisComp.marker undefined in a script?
  • Why is thisComp.marker undefined in a script?
    Posted by Mo Dejong on May 23, 2008 at 5:43 pm
    Hi all
    I am just getting started with scripting and I noticed a problem accessing the marker field in a comp object. The thing that is weird is that I can access the same field in an expression.
    I have this saved in AccessCompMarkers.jsx:
    thisComp = app.project.activeItem;
    markerKey = thisComp.marker;
    alertStr = “thisComp.name is ” + thisComp.name + “, thisComp.marker is ” + markerKey;
    alert(alertStr);
    When I run this, I see the following:
    “thisComp.name is ERHIT, thisComp.marker is undefined”
    But in the same comp, I can create an expression like:
    thisComp.marker.numKeys
    The expression will evaluate to 1, the number of comp markers
    that exist in the active comp.
    Has anyone run into this before? I have AA 8.0.0.298 on WinXP.
    thanks
    Mo DeJong
    Simon Morris replied 17 years, 9 months ago 2 Members · 2 Replies
  • Simon Morris
    November 11, 2008 at 10:54 pm
    Yes, I’ve just been experiencing this. It’s annoying, as I really need to access the comp markers… did you find a solution, Mo?
    Cheers
    Simon
  • Simon Morris
    November 12, 2008 at 12:55 pm
    I’ve done a bit more investigation and while thisComp.marker.numKeys does indeed return the correct number of composition markers, if you try and access any of the marker info such as:
    thisComp.marker.keyValue(1).comment
    You get an error that keyValue is undefined.
    So right now, I’m not very hopeful that we’ll be able to get access to those markers unfortunately.
