Activity › Forums › Audio › Why is there a ~$60 difference between these 100ft 12awg 1/4″ audio cables?
Posted by Greg Happersteen on May 2, 2010 at 5:22 pmI was looking at 100ft cable runs of 12awg 1/4″ audio cable. I found two different ones from the same manufacturer, but there is a large price difference.
Here’s the $82 cable:
https://www.bhphotovideo.com/c/product/296953-REG/Hosa_Technology_SKM_2100_1_4_Male_to_1_4_.html
Here’s the $138 cable:
Aside from the color of the sleeve, what’s the difference?
Greg Happersteen replied 16 years, 3 months ago 7 Members · 10 Replies -
Ty Ford
May 2, 2010 at 9:43 pmHello Greg and welcome to the Cow Audio Forum.
It appears as though the less expensive one is zip cord (like lamp cord) and the other one is coaxial like a guitar cord. There’s some fancy talk about oxygen free cable. Dunno what to tell you about that. If it’s just for speakers, get the cheap cable.
Regards,
Ty Ford
Want better production audio?: Ty Ford’s Audio Bootcamp Field Guide
Watch Ty play guitar -
Greg Happersteen
May 3, 2010 at 12:48 amThe cable would be for passive PA speakers powered by an amp for event setups. There would be runs of varying lengths from 100ft and 250ft.
Both types of cable that I linked to heavy duty 12awg cable, not the cheap lamp cord type of cable (20awg).
That’s why I’m scratching my head as to the price difference.
Granted, for most event setups, I’ve only seen cables with durable black sleeves, but not cables with clear sleeves. Maybe the clear sleeves aren’t as durable?
Not sure what the oxygen free cable means either. Special corrosion prevention, or sales gimmick?
Ty Ford
May 3, 2010 at 1:34 am[Greg Happersteen] “Both types of cable that I linked to heavy duty 12awg cable, not the cheap lamp cord type of cable (20awg).
“I never said it was lamp cord, I said it was LIKE lamp cord and I can read pretty well, thanks. I know what you said. 🙂
You haven’t seen 12 awg zip cord? I have. The other appears to be coaxial which may offer a modicum of shielding. As you continue to research the situation, I’m sure you find out a lot about oxygen free this and that.
Regards,
Ty Ford
Will Salley
May 3, 2010 at 3:17 amThe more expensive black cable is designed for more for rigorous use such as nightly road shows where the cable is subjected to people, beer and road cases.
The clear jacketed cable is best suited for fixed installations – but should perform equally as well – unless it’s subjected to repeated conditions described above.
Also, although they look identical, the connectors MAY be different – but not a $60 diff. There seems to be a lot of hype and snake oil when it comes to cables, especially signal cables. Some esoteric manufacturers even claim that they have “directionality” in the copper itself. Now it’s all about the power cables, with some even charging $350 for a basic 6 ft. IEC power cable. Those bozos don’t mention that it gets plugged into a 75 cent wall receptacle!
If you learn some soldering basics, you can make your own version of that same cable for about $20 in components.
Mac Pro 2×2.8 Quadcore – 10.6.3 – QT 7.6.3 – 22 GB RAM – nvidia8800GT – SATA internal & external storage – Blackmagic Multibridge Pro – Open GL 1.5.10 – Wacom Intous2 tablet – AJA io
SONY XDCAM EX3 – Letus Elite – FC7.0.2 – CS4 Prod Prem. -
John Livings
May 3, 2010 at 4:47 amHi All,
I have used these for a few years now.
The price is for 2.
https://www.speakerrepair.com/mm5/merchant.mvc?Screen=CTGY&Category_Code=ts-ts-spkr-cable
Regards, John
Jordan Wolf
May 3, 2010 at 6:10 amI recommend looking at the bulk offerings from these dealers:
Buy a 1000ft. spool and make your own – you’ll save money and learn something in the process…if you don’t want to go that route, either place also has good prices for ready-made cables.
Wolf
Richard Crowley
May 3, 2010 at 6:51 amThey are BOTH overpriced. Cable is NOT magic. Don’t throw your money away on something that makes absolutely no difference.
Joel Servetz
May 4, 2010 at 2:43 amEverything I’ve ever read about oxygen free cables says it’s all bunk, mostly sales hype. Get good quality cables with good soldered (not molded) connectors, treat them well and they should last you for many years. I have 50 and 100 foot speaker cables that have lasted for 10 – 15 years, some even longer.
Joel Servetz
RGB Media Services, LLC
Sarasota, Fl
videobyjoel@aol.com -
Ty Ford
May 4, 2010 at 3:03 amFor speaker wire, I prefer tack welding automobile jumper cables to the appropriate terminals. The tough part is not blowing up the circuitry attached, but it’s soooo worth it.
Regards,
Ty Ford
Greg Happersteen
May 24, 2010 at 9:41 pmThanks for all the input folks 🙂
I ended up going with 12awg 100ft of this cable, which ran about $80:
https://accessories.musiciansfriend.com/product/Horizon-Speaker-Cable?sku=336620
I used the cables in a big event last week, and had no problems.
