Activity Forums Adobe After Effects Why is SET MATTE effect stretching the matte?
  • Why is SET MATTE effect stretching the matte?
    Posted by Mickey Nation on January 7, 2010 at 7:54 pm
    Very new to program so chances are I’m overlooking the obvious.
    I’ve masked a moving person that I need to isolate in order to composite to a new background. I’m at the stage where I’m trying to apply the matte to the video clip. I’ve used the Color Difference Key to get the black and white traveling matte but now I’m stuck where I select the footage and add the Set Matte effect. Here’s the problem: the matte appears over my footage but it’s stretched horizontally (more and more left and right the further it moves away from the center) as to not match up with the character in the video clip which appears normal.
    I see the checkboxes next to “If Layer Sizes Differ” which are:
    * Stetch Matte To Fit
    * Composite Matte With Origin
    * Premultiply Matte Layer
    None of these checkboxes have any effect at all on this stretching matte. I’ve tried everything. Does anyone have any ideas? (I’m on CS3, Mac).
    Regards,
    Mickey Nation
    Mickey Nation replied 16 years, 7 months ago 60,002 Members · 2 Replies
  • Mickey Nation
    January 7, 2010 at 10:16 pm
    I should have mentioned that I didn’t achieve the matte using just a Color Difference Key. I rotoscoped the person with masks and keyframes, then I used the Color Difference Key to get separation from the garbage background.
    I’ll try to decipher the information you gave me — it might take a while. Thanks!
  • Mickey Nation
    January 8, 2010 at 3:44 am
    Perfect!
    It worked. It’s amazing how much things make sense once you learn them. Thanks, guy.
