Activity › Forums › Apple Final Cut Pro Legacy › Why is rendering XDCAM 422 as slow as Molasses in a SD timeline.
  • Why is rendering XDCAM 422 as slow as Molasses in a SD timeline.
    Posted by Peter Corbett on April 8, 2010 at 10:41 am
    I read a thread on this form saying “avoid XDCAM HD like the plague”, and I’m starting to believe it.
    I’m editing a SD PAL timeline with a mixture of 1080i XDCAM HD 422, ProRes DVCPRO50 and P2 HD. The XDCAM clips are taking forever to render just to play the timeline in real time without aliasing and reduced RT playback. Is this a long-GOP thing? It’s almost unworkable. I can’t render the XDCAM 422 clips into ProRes as I have 3 hours of material and a midnight deadline. Any clues anyone of how to speed this up? I have a new 2010 octo-core MacPro, 16bg RAM, fast 8-bay RAID and AJA LHe so it ain’t my system.
    Peter
    Peter Corbett
    Powerhouse Productions
    http://www.php.com.au
    Andrew Kimery replied 16 years, 5 months ago 10 Members · 29 Replies
  • 29 Replies
  • Robb Harriss
    April 8, 2010 at 11:43 am
    You’re learning the lesson I learned. Get everything in a timeline to be the same format Before editing. The whole idea of multiple formats in the same timeline is a marketing sop. Sure it does it, and rather well. But it’s a time killer and most editors, including myself, are extremely time conscious in one way or another. I want to go fast. I want the system to keep up with me. I don’t want to be waiting for it.
    Non-linear: all the time and nothing but.
  • Robb Harriss
    April 8, 2010 at 11:46 am
    our remedy is to take footage in via the Kona card in HDSDI and scale it to ProRes in real time.
  • Steve Connor
    April 8, 2010 at 12:04 pm
    I’ve just tried dropping some XDCamHD 422 clips into a PAL SD timeline on my system and they play back in real time well enough, not at full res, but more than enough to work with on a mixed format timeline, then a 20 second clip takes about 20 seconds to render. I have an older 8 core Mac, could you let us have more details on your RT settings, source material framerates etc
    Steve Connor
    Adrenalin Television
    Have you tried “Search Posts”? Enlightenment may be there.
  • Rafael Amador
    April 8, 2010 at 12:35 pm
    Do you need to deliver in XDCAM?
    If not just change the sequence codec to Prores.
    rafael
    http://www.nagavideo.com
  • Peter Corbett
    April 8, 2010 at 1:06 pm
    The video will just end up as a DVD and MP4 for web. But because 30% of the program is SD, I can’t uprez to 1080i for editing. I tried dropping a stack of AVC-Intra P2 1080 files on the same SD timeline and they rendered 10x quicker than the XDCAM 422’s.
    I have ProRes 422 (HQ) set as the compressor and “normal” for rendering. I think having to render downconversions from long-GOP is what’s doing the time damage. I agree with Robb, it’s better to preconvert to SD then edit. But this is hardly productive. I think camera guys are more amoured with XDCAMHD than editors.
    Peter Corbett
  • Arnie Schlissel
    April 8, 2010 at 1:26 pm
    [Peter Corbett] “I tried dropping a stack of AVC-Intra P2 1080 files on the same SD timeline and they rendered 10x quicker than the XDCAM 422’s.”
    That’s because the AVC-I is not long-GOP. It’s recorded in camera as whole frames. The XDCam is recorded in camera as 12 or 15 frame groups, and those groups need to be decoded into individual, whole frames.
    Arnie
    Post production is not an afterthought!
    https://www.arniepix.com/
  • Arnie Schlissel
    April 8, 2010 at 1:28 pm
    [Robb Harriss] “our remedy is to take footage in via the Kona card in HDSDI and scale it to ProRes in real time.”
    [Robb Harriss] “Non-linear: all the time and nothing but.”
    I don’t know, Robb… That solution sounds very, umm… linear to me…
    (wink, wink, nudge, nudge)
    Arnie
  • Mark Maness
    April 8, 2010 at 1:35 pm
    BINGO!
    Arnie hit it on the nose! That’s why when your doing projects with multiple media that you really really need to down-convert your footage to match the rest for the edit.
    Hardware conversion is a thousand times better than software conversion. This is an area that most people overlook when purchasing hardware, and what you are seeing here is usually the result of that decision making process.
    This is why I have always said that cutting corners sometimes can bite you in the butt!
    _______________________________
    Wayne Carey
    Schazam Productions
    https://web.mac.com/schazamproductions
    schazamproductions@mac.com
  • Rafael Amador
    April 8, 2010 at 1:40 pm
    [Peter Corbett] “The video will just end up as a DVD and MP4 for web. But because 30% of the program is SD, I can’t uprez to 1080i for editing. I tried dropping a stack of AVC-Intra P2 1080 files on the same SD timeline and they rendered 10x quicker than the XDCAM 422’s.
    I work in a MBP with XDCAM 422 (some times 220Mbps, from the NANO).
    No problems.
    Any thing, but rendering to XDCAM.
    XDCAM is an acquisition format. For production is probably one of the slowest available option.
    And you don’t need it at all.
    Set Prores in you sequence and render.
    rafael
  • Peter Corbett
    April 8, 2010 at 1:45 pm
    I’m not having issues in a HD project with XDCAM 422. It’s using XD clips in a SD timeline that causes a meltdown. The DOP we used on this job has a PDW700, but I’d be cautious about buying one myself. That said, the pictures in 1080 from the camera look incredibly sharp.
    Peter Corbett
Page 1 of 3
