Activity Forums Adobe Premiere Pro Why is Premiere Pro 1.5 suddenly NOT rendering!
  • Why is Premiere Pro 1.5 suddenly NOT rendering!
    Posted by Jim on June 9, 2005 at 10:17 pm
    Hi there
    Need major help! I cannot render out any of my project as Premiere Pro 1.5 locks up as soon as I start the render. This has only happened in the last week, I haven’t installed any programs that would have changed it, it just will not render.
    I am running AJP D900t – Pentium 4, 3.40 GHZ, 1gb ram – I can’t understand why this has just started happening.
    Jim
    stolencherry@hotmail.com
    Jim replied 21 years, 2 months ago 2 Members · 2 Replies
  • David J
    June 9, 2005 at 10:36 pm
    Just a guess.
    Rendering creates temporary files on disk,.
    You might check where the temp files are being created, ensure there is enough disk space free, and run a disk test to see if there is an issue with the volume.
  • Jim
    June 10, 2005 at 7:25 am
    Cheers, but that wasn’t the problem, it seems to be a problem with color finesse and premiere. I have managed to work around it, as long as Premiere isn’t trying to render color finesse first, then it works (i.e i stick another plug in above it!!!)
    Oh, what you have to do to get software to work:-)
