Activity › Forums › Boris FX Particle Illusion › why is particle moving fast even velocity is set to 0?
  • Francois Blawat
    April 15, 2017 at 2:42 am
    Pete,
    Try looking at this older Thread (Titled: Slowing down Particles) Located here: https://forums.creativecow.net/archivethread/23/497798#498149
    It talks about decreasing something called the Force Strength if you are using a Force object.
    I’m not sure that is what you were looking for, but this forum search function hopefully can also help you find your solution.
    -Francois
    FixitMad
