Activity › Forums › Apple Final Cut Pro Legacy › WHY IS MY PROJECT FILE SO BIG? problems opening on other computer
  • WHY IS MY PROJECT FILE SO BIG? problems opening on other computer
    Posted by Paul01 on February 1, 2006 at 6:20 am
    WHY IS MY PROJECT 207 MB BIG? THERE ARE ABOUT 15 SEQUENCES OF 8 MINUTES IN IT, EACH SEQ HAS ABOUT 3 VIDEO TRACKS AND 6 AUDIO TRACKS.
    I ALSO HAVE A PROJECT ON MY COMPUTER THAT HAS MUCH MORE IN IT (FEATURE LENGTH CUT, HUNDREDTS OF CLIPS) THAT IS ONLY 3.5 MB IN SIZE. Why?
    That 207 mb project won’t open on an other system. I tried making a new project with only the couple sequences we needed (39.8mb still!!!), it still would not open on other system…
    Both macs have 1.67 gig processors.
    What should we do?
    Paul01 replied 20 years, 8 months ago 3 Members · 3 Replies
  • Paul Dickin
    February 1, 2006 at 4:09 pm
    HI
    An ex-Avid colleague and I edited two archive footage shows using FCP. My project for the two-hour timeline came to about 10MB.
    His came to 194MB before the Mac gave up and failed to complete it!!!
    What he was doing was creating a timeline of cut source footage, about 20-40mins, then opening a new project and dragging that sequence into the new project, and closing the first project.
    So his new project had no clips in the Browser, just a sequence.
    After he had done this about 15 times he had created his 194MB masterpiece, with no source clips anywhere in sight in his final project – just sequences that referenced earlier unopened projects. So in effect every project he had ever worked in had to be invisibly opened by his final project for it to know anything about all his nested/nested/nested… timeline clips.
    I don’t know if any of this applies in your case, but I finished the show by creating a new project using the timecode data of his clips – which was down to 10MB again 😉
    (I hadn’t realised that Avid clip management was so different to FCP’s.)
  • Dan Riley
    February 2, 2006 at 10:51 pm
    The number of sequences and the number of nests you do,
    these are what determine project size, mostly.
    If you don’t do nests, you will not have any trouble.
    Like the last guy said, whenever FCP has to reference
    media or a nested sequence, from within another sequence,
    that makes the project much more complicated from a
    size standpoint.
    Dan
  • Paul01
    February 3, 2006 at 10:02 pm
    yes that is exacty waht happend with my project!
    what should i do to make it smaller? nest?
