Activity › Forums › Adobe After Effects › Why is my composition background a frame from a previous project?
  • Why is my composition background a frame from a previous project?
    Posted by Poppy Stone on August 17, 2019 at 1:59 pm
    Hello!
    I’m relatively new to after effects, and I have a question about my composition background. For some reason, whenever I make a new composition, it says my background is black, but when I make it, the background is a frame from one of my previous projects.
    This has happened to me twice now. To fix the problem before, I switched my renderer from Cinema 4D to Classic 3D. Now that the problem has happened before, both renderers have a random frame stuck there. I don’t know how to fix it!
    I am running After Effects CC 2019.
    I’m so sorry if this was confusing!
    Richard Garabedain replied 7 years, 1 month ago 4 Members · 3 Replies
  • Joe Rodgers
    August 17, 2019 at 6:14 pm
    It sounds like you need to toggle transparency grid. In your composition window, just to the left of your camera view dropdown is a rectangular icon. Click on that and it should fix the problem.
  • Walter Soyka
    August 17, 2019 at 9:26 pm
    After Effects saves rendered frames to memory and to disk, to make subsequent previews and renders faster. If you ever see an incorrect stuck frame, try purging that cache:
    Edit > Purge > All memory and dish cache…
    Walter Soyka
    @keenlive   |   RenderBreak [blog]   |   Profile [LinkedIn]
  • Richard Garabedain
    August 20, 2019 at 3:13 pm
    it happens all the time…never render without a background or else that will happen
