Activity › Forums › Adobe Premiere Pro › Why is my clip exporting so dark??
  • Why is my clip exporting so dark??
    Posted by Zvi Twersky on April 17, 2007 at 8:40 pm
    I made a clip with premiere pro2. The clip is so dark! I have never had this problem but it IS the first time I was using top quality HD footage. Not sure this should be the cause. I expoted the 3 minute clip to wmv format, reducing the quality for upload but if you will take a look, mostly in the last 2 minutes at the dancing, it is so dark (some places in the dancing, you can see frames that the sides are all black!) and when I look at it on the premiere pro, it’s so bright and normal, and there doesn’t seem to be any color problem!
    Here’s the clip:
    https://www.youtube.com/watch?v=mi7KfUjf4oc
    What could be wrong?
    Thank you
    Vince Becquiot replied 19 years, 5 months ago 3 Members · 3 Replies
  • Steven L. gotz
    April 18, 2007 at 12:40 am
    Zvi,
    I don’t see any problem. Have you looked at it on a different PC?
    Steven
    https://www.stevengotz.com
  • Zvi Twersky
    April 18, 2007 at 7:11 am
    People are telling me the same thing, that it looks fine. I WILL check it on another screen to see if you are seeing what I see on the screen at work. (I made the clip at work and previewed it at home.)
  • Vince Becquiot
    April 18, 2007 at 7:00 pm
    The best thing in this case is to get a second opinion by looking at the waveform monitor. Make sure that everything is spread out between 7.5 AND 100.
    Vince
