Activity › Forums › Apple Final Cut Pro Legacy › why is “make subclip” greyed out?
  • why is “make subclip” greyed out?
    Posted by Bob Flood on September 9, 2008 at 4:17 pm
    Hi
    I have a sequece of selects. i “f” one into the viewer. it has in and out points based on what was cut into the sequence. When i hit command u nothing happens, and when i go to the Modify menu “make Subclip” is greyed out.
    I haver done this before, what would prevent it from working now?
    thanx for your help
    ps I know i can do it in media manager, but i juat want to do a couple of shots and it seemed faster this way, when it works
    “I like video because its so fast!”
    Bob Flood
    Greer & Associates, Inc.
    Jeremy Garchow replied 18 years ago 2 Members · 2 Replies
  • Bob Flood
    September 9, 2008 at 4:26 pm
    Hey Bob
    maybe subclip is greyed (grayed?) out because you somehow un linked the clips in your sequence to the clips in the browser, you knucklehead!
    WHen you press shift f you will get a message telling you that “there is no master cip in the browser, do you want to make one?”
    so now you Have to use Media manager! nice goin porcupine!
    Bob Flood
  • Jeremy Garchow
    September 9, 2008 at 4:59 pm
    If you drag your clips from your sequence to a bin, you might get what you want.
    Sounds like you might have made the seq. clips ‘independent’.
