Activity Forums Apple Final Cut Pro Legacy why is log and capture so difficult?
  • why is log and capture so difficult?
    Posted by Redman on August 14, 2006 at 5:15 am
    i have upgraded from a g3 to a g4 and now i have a quad g5 with fcp5. i still have problems inputing my video using log and capture. the audio always works but the video does not. i reseat cables. cycle vcr power. cycle fcp5. reboot the g5. eventually it works. is there a sure fire way to capture first time every time? is it my vcr that causes the problems? usually when i reboot the g5 that works. now the g5 is crashing. i guess i have to trash the prefs. thx in advance.
    Bret Williams replied 20 years, 1 month ago 4 Members · 5 Replies
  • Bret Williams
    August 14, 2006 at 5:22 am
    You have a VCR and not a VTR? Yeah, a VCR would definitely be the problem. No real video sync. You need to be using at least semi pro gear like a cheap DV camera with TC. Tell us exactly what your setup is.
  • Thaxter Clavemarlton
    August 14, 2006 at 1:04 pm
    I can honestly say I NEVER have problems with Log and Capture when I’ve marked my INs and OUTs and then Batch Captured using a DV deck (or camcorder) connected via FireWire.
    You didn’t say WHAT your “VCR” was or how it was connected.
    Can you be VERY SPECIFIC as to your set-up, so we might be a bit more helpful?
  • Redman
    August 14, 2006 at 3:39 pm
    my bad. i am using a pd150 with the fire wire. alot of times i must use the uncontrolable device option. the projects i edit do not require time code. thx for your reply in advance.
  • Walter Biscardi
    August 14, 2006 at 3:42 pm
    [redman] “my bad. i am using a pd150 with the fire wire. alot of times i must use the uncontrolable device option. the projects i edit do not require time code. thx for your reply in advance.”
    Uncontrollable device is never a good way to digitize. Shoot with proper timecode and then use machine control to digitize.
    Walter Biscardi, Jr.
    HD Editorial & Animation for Food Network’s “Good Eats”
    HD Editorial for “Assignment Earth”
  • Bret Williams
    August 14, 2006 at 4:54 pm
    Why on earth would you do that? Don’t do that.
