Activity › Forums › Apple Final Cut Pro Legacy › Why is it so hard to make a DVD?
John Pale
September 6, 2010 at 5:52 pmOh…and yes…and do check what Michael said!
Apple really should remove the option to create an HD-DVD…the format is dead and does nothing but cause confusion. It should NEVER be used. You cannot switch to SD, after the fact either. You must create a new SD DVD project.
Bret Williams
September 7, 2010 at 5:11 amIt has been shown in a few recent threads that VBR can cause funkiness. It happens very sporadically for me, like once a year. Detailed backgrounds start to strobe. So I try CBR. Sharper, and no stutter. Plus it renders faster.
As others have pointed out, the VBR is for compressing longer pieces that wouldn’t otherwise fit. Or, to get a higher data when when possible, when that rate wouldn’t work at CBR.
Kinda like web encoding.
Bret Williams
September 7, 2010 at 5:13 amAnd who would play these Blu-Ray Discs? I don’t even have a Blu-Ray player.
