Activity Forums Adobe Illustrator Why is it drawing hidden strokes
  • Why is it drawing hidden strokes
    Posted by Steve Wilson on May 11, 2016 at 6:25 pm
    Hello
    I have a question related to Illustrator and Video Scribe. It is hard to explain so I did a video. The video shows you what I did to set things up so you can answer the question at the end of the video concerning drawing strokes that are hidden in Illustrator. It is about 80 seconds so hopefully I don’t bore you too much.
    If you watch, I know some will tell me the solution is to do the 2 images separately in Illustrator but the problem is part of a larger project and I didn’t want to bore you with all the details — so the solution to do them in Illustrator separately won’t work for the larger project.
    Your thoughts/solution on why illustrator draws the hidden strokes in videoscribe and any solution would be appreciated.
    I uploaded the video to youtube.
    Here is the link:
    https://youtu.be/fBhUSr5ju6Y
    Steve Wilson replied 10 years, 3 months ago 1 Member · 1 Reply
  • Steve Wilson
    May 11, 2016 at 9:11 pm
    Hello
    I just found out that this is a videoscribe problem so I’m sure it can’t be answered here.
