Activity Forums Adobe InDesign Why is ID still adding 1 point in script
  • Why is ID still adding 1 point in script
    Posted by Miroslav Hora on May 12, 2009 at 1:12 pm
    Hi folks!
    I am quite new to scripting ID so here is first issue I can’t get solved.
    I wrote a js where the dialogue window pops up and asks for dimensions of a new rectangle to add. This new rectangle is created with exactly those values I’ve inserted in the dialogue but with 0.353(or one point)added. For example – If I would insert 10,10 into dialogue the produced rectangle would have 10.353, 10.353. Any Idea? Thx for advice
    https://kreativec.com
    Prague – CZ
    Terry Mikkelsen replied 17 years, 4 months ago 2 Members · 1 Reply
  • Terry Mikkelsen
    May 15, 2009 at 12:41 am
    There are stroke options which may be the problem. The options are to have the stroke “inside” the box, “centered” or “outside”.
    I know in CS3, if I draw a box that is 10 x 10 and then change the stroke option, it will change the overall dimension of the box.
    Tech-T Productions
    http://www.technical-t.com
