Activity Forums Adobe Encore DVD Why is Encore Re-Transcoding H.264 Blu-ray files created with Adobe Media Encoder?
  • Why is Encore Re-Transcoding H.264 Blu-ray files created with Adobe Media Encoder?
    Posted by Bill Celnick on October 7, 2011 at 8:58 pm
    Hello
    I’ve successfully created Blu-Ray dvds via this method before – can’t seem to figure out what’s wrong this time. Using Encore 5.1 – Mac.
    Working in FCP, and exporting my timeline via Quicktime Export – HDV (MOV). Importing this MOV file into Adobe Media Encoder, and creating both web h.264 and Blu-Ray H.264, using Adobe’s preset.
    When importing the Blu-Ray H.264 into Encore, Encore reads it as untranscoded, and retranscodes with the result being a very poor quality Blu-Ray disc – looks worse than SD.
    Why does Encore need to re-transcode what Adobe Media encoder already created? Would it be best to simply import my mov file into Encore and skip Adobe Media Encoder altogether?
    Thank you.
    Bill
    Bill Celnick replied 14 years, 11 months ago 3 Members · 3 Replies
  • Chris Tompkins
    October 9, 2011 at 5:02 pm
    Set the re-encode preferences from within Encore.
    Also, I think encore preferres mpeg for Bluray.
    Chris Tompkins
    Video Atlanta LLC
  • Daniel Ludwig
    October 9, 2011 at 8:22 pm
    NOP, wont agree with MPEG.
    encore will exept MPEG2(HD) or H264 for blu-ray.
    you need to set the transcoding-settings within your project-settings at the start of your project to match your H264-file, otherwise it will be transcoded again!
    NOTE: all menus will allways be transcoded to MPEG2HD, so for menus you should use MPEG2 or quicktime-movies and let encore do the transcoding-job.
    also be awared that HDV nativly only have 1440×1080 and no 1920×1080, that could also cause the problem, as you need to set that within your project preferences/transcoding-settings as well.
    compressor H264 are 100%-BD-spec-complient and will be accepted by encore.
    cheers
    danny
  • Bill Celnick
    October 10, 2011 at 4:08 pm
    Thank you both – I went back and re-examined what I did – when I brought my mov file into Adobe Media Encoder, I started with the default(match source attributes) using h.264 Blu-ray, but then went into the settings and changed it from one pass to two pass vbr – figuring that I’d get a better quality file. Maybe it caused Media Encoder to create file Encore couldn’t accept.
    I went back to the same source file, and again encoded, but with no modification to the settings and it worked.
