Activity Forums Apple Final Cut Pro Legacy Why is Disconnected Media Such a Disaster?
  • Why is Disconnected Media Such a Disaster?
    Posted by Collin Alexander on July 30, 2010 at 9:54 pm
    If the hard drive gets disconnected for whatever reason, all the media goes offline. This makes sense. But when the hard drive re-mounts, why is it such a disaster for Final Cut? Why must all media now be painstakingly re-connected? All files are still in the right place, the file references in Final Cut have not changed.
    There must be some technical explanation for why Final Cut cannot simply pick up where it left off. I’d rest a little easier if I understood.
    Jason Brown replied 16 years, 1 month ago 3 Members · 2 Replies
  • Michael Gissing
    July 31, 2010 at 12:51 am
    Simple answer is that if you save the project file with media disconnected it remembers the disconnect state and you have to reconnect. This is a pain but if your media is well organised, and you have studiously avoided file name duplication, it can reconnect quickly.
    I have had this happen and the easiest thing was to shut down without saving.
  • Jason Brown
    July 31, 2010 at 12:54 am
    After effects does a way better job of retaining links and regaining them. I wish fcp would pick some ideas from how effective that linking process is. Their basic function is VERY similar…
