Activity Forums Adobe After Effects Why is After Effects previewing so slowly?
  • Why is After Effects previewing so slowly?
    Posted by Martin Kruul on November 18, 2016 at 7:32 pm
    I don’t know what to do at this point. I’m working on a very time sensitive project, and have (in my opinion) a fairly simple graphic animation – but After Effects previews it SO SLOWLY that it’s KILLING my productivity.
    Essentially, I have text that I basically converting into Masks and have a Stroke effect revealing it. I figured this wouldn’t be too intensive, since it’s just a stroke reveal on text, but After Effects previews this LETTER BY LETTER. As there’s a lot of text, I need desperately for this previewing to go faster.
    Is there anything I can do to speed up my After Effects previews. I’m already rending at a Quarter of the resolution and Fast Draft removes the text entirely for some reason. I’ve allocated almost all of my RAM to AE (I only have 16 gigs, but I have 13 going to AE directly) and I’ve shut down every other program. I don’t know HOW to get AE CC to use multicore processing, as it seems they removed that.
    Any advice would be GREATLY appreciated!
    Uwe Felski replied 9 years, 6 months ago 6 Members · 7 Replies
  • 7 Replies
  • Kilian Le dantec
    November 18, 2016 at 8:00 pm
    Hi Martin !
    – Maybe try to purge your cache if it’s not done yet. EDIT > PURGE > ALL MEMORY AND DISK CACHE.
    – Also, you can go to the preview window a crank up the “Skip frame” value. It’s not the best to see exactly what you are doing, but it gives a pretty good idea what the result looks like, and if you’re in a rush …
    – Disable the Motion Blur if it’s on !
    Hope it helps, cheers !
  • Eric Santiago
    November 18, 2016 at 8:23 pm
    If its CC 2017 or CC 2015 (any version) your SOL!
    I can tell you that on any powerful 64GB Mac, that app is slow at preview.
  • Michael Szalapski
    November 18, 2016 at 8:31 pm
    Are you accidentally set to the ray-traced renderer?
    If so, switch to the classic renderer or, if you’re using 3d depth, use the Cinema 4D renderer (which is multithreaded for rendering the 3d geometry, by the way) and it should go much faster.
    – The Great Szalam
    (The \’Great\’ stands for \’Not So Great, in fact, Extremely Humble\’)
  • Martin Kruul
    November 18, 2016 at 9:17 pm
    Hi Michael – where exactly would I see which renderer I’m currently set to?
  • Michael Szalapski
    November 18, 2016 at 9:37 pm
    Composition settings or the little area in the top-right of your composition. (Only visible if you have 3d layers.)
    – The Great Szalam
  • Walter Soyka
    November 19, 2016 at 3:44 pm
    [Martin Kruul] “I don’t know HOW to get AE CC to use multicore processing, as it seems they removed that. “
    You can work in Ae CC 2015.x and render in Ae CC 2014 without difficulty — they use the same project file format. If you want to work in the new release Ae CC 2017, you’ll have to down-save to use Ae CC 2014’s multiprocessing feature for faster final renders.
    Walter Soyka
    @keenlive   |   RenderBreak [blog]   |   Profile [LinkedIn]
  • Uwe Felski
    February 24, 2017 at 6:39 pm
    What worked for me was this:
    There are 2 apps, gpu-z (win) or cuda-z (mac)
    I was just launching cuda z on mac (it monitors the gpu details) and than started after effects …. BAMM! couple times as fast on realtime performance on GPU accelerated fx like glow.
    I don’t know what it did but it worked… all the Terminal Cuda suported card .txt. stuff i’ve been doing since cs6 didn’t really do anything for me in cc2017. will try gpu-z on windows too.
