Activity Forums Avid Media Composer Why is a playhead always automatically an In point?
  • Why is a playhead always automatically an In point?
    Posted by Jiri Fiala on March 1, 2025 at 1:36 pm
    In Avid, if I do not specify an In point, the current frame under the playhead is used as one. That is very weird coming from another NLEs that do not assume this and if I/O is not set, it uses the entire clip. Avid’s way throws me off for clips that are used in their entirety (VFX, animations, SFX…) and it forces the user to either Home the playhead first or press T to select the entire clip. Weird!
    This is more an observation than a question but I’d like your thoughts on this. I find it very weird that Avid has all sorts of modes, options and toggles for editing but something as basic as this is just a given.
    Glenn Sakatch replied 1 year, 5 months ago 3 Members · 2 Replies
  • Neil Ryan
    March 2, 2025 at 10:00 pm
    You’re right; this is an observation, not an error. Avid was developed decades ago, by film editors. Much of it was based on how editing was done on film. You can find many critics of Avid these days but, fundamentally, Avid Media Composer – at the basic editing level – remains one of the best editing systems because they got so much right at the beginning. That you find one function difficult because it operates different from the system you’re used to, simply highlights that there are different ways to do things, in this case, when the user doesn’t do something, and the system has to make an assumption. Avid’s assumption works well because it works the same on both the source and record sides. Plus, that assumption carries through to other parts of its editing practices.
    Definitely not an error. And, in my opinion, a great way to work.
  • Glenn Sakatch
    March 23, 2025 at 3:54 pm
    I believe if you go into the combined view mode for script and text…can’t remember what it is called, select all the clips, and hit the “A” button, it will send all those clips to the start frame.
    Then you can edit all your vfx the way you want it to work. Personally, i like using the position bar as a mark point about 90 percent of the time. The other 10 percent, i say “crap” under my breath, redo the edit and move on. I swear 20 years ago, the inpoint and outpoint were cleared on the record side after an edit was done. That doesn’t seem to happen anymore…that buggers me up more than anything else.
