Activity › Forums › Adobe After Effects › Why doesn’t the AE Numbers plug-in have commas???
Declan Smith replied 10 years, 4 months ago 8 Members · 27 Replies
Luc Nutter
December 7, 2012 at 9:24 amThanks for the script, Declan. It was exactly what I was looking for, and your posts helped me a lot!
Cheers,
Luc
Barry Rubin
August 8, 2013 at 4:10 pmCan you further explain “first make sure your number is a string, then add from the .replace part as below:”
Thanks Barry
Love is great
Barry R.
Jamie Buck
February 13, 2014 at 7:49 pmHi Declan,
I am using the code you provided to put that includes the dollar sign in front of the number, but I was wondering if its possible to also include the 2 decimal places. ( i.e. $1,000.12)?
Declan Smith
February 13, 2014 at 8:43 pmThis thread lives again!
The bit that is truncating the decimal point is where it says ‘toFixed(0)’. If you want two decimal places, then this needs to change to ‘toFixed(2)’. The full modified expression as below:
"$" + (effect("Point Control")("Point")[0].toFixed(2)).replace(/(\d)(?=(\d{3})+(?!\d))/g, "$1,");Declan Smith
https://www.madpanic.tv
After Effects CS6/ FCS3 / Canon XLH1 / Canon 7D / Reason / Cubase“it’s either binary or it’s not”
Liran Tabib
April 22, 2016 at 7:15 amkeeping this thread alive!
if you are tired of programming your way out of counter animation you can use this Counter preset:https://www.vdodna.com/products/counter-preset/ -
Felipe Santamaría
May 11, 2016 at 3:30 pmHey Declan,
I’ve used this code before for animated counters, so THANK YOU SO MUCH, but there’s somenthing I’ve been unable to do.
Some times I’ve been asked to use commas to separate thousands and points to separate decimals (1,000.10), but sometimes I’ve been asked the opossite, to separate decimals with commas and thousands with points (1.000,10).
How can I do this?
Thank you for this code. This thread lives again!
Declan Smith
May 11, 2016 at 5:55 pmWow, this thread really does live on. Ok, if you want to do as you are saying, then try this. Basically, replace the “.” with “,” then add the separator as a “.”
num = "$" + (effect("Point Control")("Point")[0].toFixed(2)).replace(".", ",").replace(/(\d)(?=(\d{3})+(?!\d))/g, "$1.");
Hope this is what you’re after.
Declan Smith
After Effects CS6/ FCS3 / Canon XLH1 / Canon 7D / Reason / Cubase\”it\’s either binary or it\’s not\”
