Activity › Forums › Avid Media Composer › Why doesn’t playhad move to timecode I enter?
Posted by Milton Hockman on March 16, 2009 at 3:41 pmyou know how you can type in numbers like 01:00:00:00 to make the timeline playhead jump to that part onthe timeline?
well, mine does not work anymore. I type in the numbers and nothign happens just a BEEP sound.
how do i fix?
Motion Graphics Artist and Non-Linear Editor
Software expertise include: After Effects, Avid Xpress Pro, Final Cut Pro, Dvd Studio Pro, Photoshop, and more.Adam Bernardi replied 10 years ago 7 Members · 10 Replies -
Michael Hancock
March 16, 2009 at 3:51 pmDo you have Numlock on?
Also, do you have Timecode displayed on your Source/Record monitors? If you have I/O or Duration or anything other than Timecode as the top display it doesn’t work.
Michael
Milton Hockman
March 16, 2009 at 6:28 pmTHAT’S IT.
I HAD MY IN/OUT DISPLAYED ABOVE MY TIMECODE ON THE COMPOSER MONITOR.
SWITCHED THEM AND NOW IT WORKS.Motion Graphics Artist and Non-Linear Editor
Software expertise include: After Effects, Avid Xpress Pro, Final Cut Pro, Dvd Studio Pro, Photoshop, and more. -
Terence Curren
March 18, 2009 at 1:12 pmHere’s another tip. You don’t need to enter the hour if you are within the same hour. In other words, if you want to jump to 1:01:26:10 and you are anywhere in the 1 hour range, just type 12610 and enter.
Terence Curren
http://www.alphadogs.tv
http://www.digitalservicestation.com
Burbank,Ca -
Marc Tidalgo
August 11, 2009 at 4:45 pmHi, I’m also having this problem, but my num lock isn’t on and i don’t have I/O or anything else but V1 TC1 in the monitor. What’s also odd is that the time code entering thing works on other clips in the project, but won’t work for clips from this one specific interview.
Thanks in advance for any help!
-Marc Tidalgo -
Terence Curren
August 11, 2009 at 5:01 pm[Marc Tidalgo] “What’s also odd is that the time code entering thing works on other clips in the project, but won’t work for clips from this one specific interview.
“Are you sure that clip has TC?
Also, what type of TC. For example. If you have V1 source TC selected, but the clip is audio only. Nothing will happen when you enter a number. You would need to select audio TC above the monitor.
Terence Curren
Burbank,Ca -
Marc Tidalgo
August 11, 2009 at 6:33 pmThe interview clip def has TC, and video as well as audio tracks (just for kicks I have both V1 TC1 as well as A1 TC1 above the source monitor, but typing in the TC still does not move the play head).
Mike Stanley
May 29, 2014 at 9:51 pmI’ve been having problems with the same thing. Mine worked when I switched from DF to non-DF time code. See if that works…
Adam Bernardi
September 21, 2016 at 4:48 pmI’m having the same problem and none of these solutions worked. I am working in a 23.98 project and my source that’s giving me problems is 24. Could that be the problem?
Michael Phillips
September 21, 2016 at 5:56 pmAre you in a NTSC 23.976 project or 1080 23.976 project? And is your source 24.000 speed or are you referring to 24 timecode, as both 23.976 and 24.000 use 24 frame timecode.
Michael
Adam Bernardi
September 21, 2016 at 9:00 pmI’m in 1080 23.98 project, but my source is true 24.000 speed. In addition, that’s my pic only, my tracks were brought in at 23.98 and if I put one of them in the upper window, then entering the timecode works. But with the pic in the upper window, it just sits there… staring at me…
