Activity Forums VEGAS Pro Why does Vegas 8.0c show that max available memory is 1024 MB since I have 2GB RAM?
  • Why does Vegas 8.0c show that max available memory is 1024 MB since I have 2GB RAM?
    Posted by Fotis Vassis on October 27, 2008 at 4:44 pm
    I have 4×512 same memory sticks Kingston HyperX Dual Channel Kits installed and Win XP shows correctly 2GB Ram in system properties.
    However in Vegas in Dynamic RAM Preview settings I can see that I can set it up to 1024 as this is what Vegas show as max.
    Is this a bug or something else?
    Thanks in advance
    Interchefs Culinary Club
    The Interactive Gourmet Experience
    John Rofrano replied 17 years, 11 months ago 4 Members · 6 Replies
  • John Rofrano
    October 27, 2008 at 4:43 pm
    It is not a bug. If you have 2GB of RAM it would be physically impossible to allow it all to be used for RAM preview since the Windows OS and Vegas application itself need RAM to run. Vegas allows you to allows 1/2 of the total RAM which for you is 1024MB.
    ~jr
    http://www.johnrofrano.com
    http://www.vasst.com
  • Fotis Vassis
    October 27, 2008 at 5:01 pm
    Thanks John for the answer, but the issue is that some months ago I had 2×512 Ram installed and in Vegas it showed max again 1024. Later I found the same kit to buy and made it 4×512.
    I have also found a second hand 4x1gb kit at unbeatable price( I expect WinXP to be able to show 3.5GB in system properties) but I really wonder if Vegas will be able to show 2GB max then?
  • Enrique Orozco
    October 27, 2008 at 7:19 pm
    I have 4 GB of RAM and Vegas 8C shows only 1024 … maybe Vegas 8.1 on 64 bits will be different ???
    regards
    Enrique Orozco R.
    http://www.dvideostudio.com
  • Fotis Vassis
    October 27, 2008 at 7:46 pm
    I posted the same question in Sony’s forum and a guy answered that Vegas can go as high as 1024. Maybe this is the case.
    By the way Enrique, you have 4GB ram on 32bit XP? Does it show full 4GB in system properties or 3.5?
  • Steve Rhoden
    October 27, 2008 at 7:48 pm
    It is not necessary being concerned over this issue,its
    impact in your real world editing workflow is basically insignificant at best.It can always stay at its default setting.
    Steve Rhoden
    Creative Director
    TNX EFFECTS STUDIOS.
    sample bits at
    http://www.youtube.com/hentys
  • John Rofrano
    October 27, 2008 at 11:40 pm
    As I said, Vegas will always show 1/2 of the available RAM. It doesn’t matter that the physical RAM in your computer is 4GB, Windows XP has an imposed limit that each application cannot use more than 2GB of RAM for data unless they are Large Address Aware (which none of the Sony products are). So Windows is giving Vegas 2GB of your 4GB of memory and Vegas is letting you choose up to 1/2 (1GB) for RAM preview.
    ~jr
