Activity Forums Apple Final Cut Pro Legacy why does this happen??
  • why does this happen??
    Posted by Derek Nagle on March 16, 2008 at 10:53 pm
    hey all,
    i am editing multicam, i have the playhead sync on canvas and viewer both set to ‘open’ rt set to unlimited and multiclip playback,
    but when i try to play it video full size on the viewer,
    it was grand i have half the project finished, then saved it opened up now this
    any tips for fixing this
    cheers
    Derek Nagle replied 18 years, 6 months ago 3 Members · 7 Replies
  • 7 Replies
  • Don Greening
    March 16, 2008 at 11:05 pm
    [derek nagle] “any tips for fixing this”
    Fixing what? Do you mean the video is playing full size in the viewer now and it won’t play back properly? You can’t see the full video frame in the viewer? If that’s the case then choose “Fit To Window” in the drop down menu in the Viewer or Canvas windows.
    – Don
  • Derek Nagle
    March 16, 2008 at 11:16 pm
    no the multicam wont work, what ever is on the timeline will play in the viewer and i cant change angles
  • Don Greening
    March 16, 2008 at 11:23 pm
    Sounds like you have everything set correctly. Do you have “Show Multiclip Angles” checked? If that’s not it then quit FCP, trash the program’s preference files then restart FCP and see if that’s solved it.
    – Don
  • Derek Nagle
    March 16, 2008 at 11:29 pm
    where is the Show Multiclip Angles option?
    this happens alot when i multicam editing
  • Don Greening
    March 16, 2008 at 11:36 pm
    [derek nagle] “where is the Show Multiclip Angles option? “
    I can’t remember and I’m not at my edit suite at the moment. Just start pulling down menus. Maybe the “View” menu?
    Another reason the same video will play in both the viewer and canvas windows at the same time is if you’ve used the “collapse muliticlip” command by mistake, or that your multiclip track has been disabled or muted. You can expand the multiclip track again if it has become collapsed.
    – Don
  • Andy Mees
    March 17, 2008 at 10:43 am
    go to Tools menu > Render Manager… and trash the renders on this sequence/project
    or toggle off visibility on your video track then toggle it back on again, that should also cause FCP to lose the renders
    see if that helps
  • Derek Nagle
    March 17, 2008 at 5:06 pm
    andy ur a legend it worked!
