Activity › Forums › Adobe After Effects › Why does the “Glow Intensity” do nothing?
  • Why does the “Glow Intensity” do nothing?
    Posted by Robert Ditty on December 9, 2018 at 7:57 am
    I have added the glow effect to these vector sun ray shapes from a logo in my video. Here it is with the Glow intensity set to 1.0:
    Here it is with the Glow intensity set to 255:
    No difference at all. It doesn’t matter what parameters I change, it makes no difference. Any help would be a appreciated.
    Simon Ubsdell replied 7 years, 9 months ago 4 Members · 4 Replies
  • Kalleheikki Kannisto
    December 9, 2018 at 11:15 am
    I have the feeling that the effect is already pretty much maxed out at 1.0, especially if you’re at 8-bit. Does anything happen between 0 and 1? Does changing the glow radius do anything?
    Have you tried changing the color depth of the project to 16 or 32 bits? I believe that remaps the slider to a different range and 32 bits might allow going beyond the “full” value.
    Senior Graphic Designer
  • Simon Ubsdell
    December 10, 2018 at 11:55 am
    Your radius is very small. Try increasing it.
    Also try using the alpha channel and using A&B Colors.
    Simon Ubsdell
    tokyo productions
    hawaiki
  • Eric Santiago
    December 10, 2018 at 3:10 pm
    That option has always been about luminance.
    You have to be a little more creative with your layers to get that to work.
  • Simon Ubsdell
    December 10, 2018 at 3:18 pm
    [Eric Santiago] “That option has always been about luminance.”
    If you use the Alpha Channel instead of the Color Channels and set the Glow Color to A&B Colors it doesn’t matter what the “luminance” of your source layer is.
    Simon Ubsdell
    tokyo productions
    hawaiki
