Activity › Forums › Apple Final Cut Pro › Why does rendering/Transcoding stop in FCPX?
  • Why does rendering/Transcoding stop in FCPX?
    Posted by Don Scioli on September 6, 2011 at 10:12 pm
    Does anyone know why transcoding and /or rendering stops in FCPX seemingly for no reason…then you have to go to the background tasks window and click around to get it going again. The it stops again, more clicking etc.
    I’m using a MacPro 3.2 Ghz, 16 GB ram, GTX video cards so speed should not be a problem.
    Thanks in advance.
    James Cude replied 15 years ago 3 Members · 4 Replies
  • Matthew Celia
    September 6, 2011 at 10:18 pm
    If skimming is turned on and you are skimming through clips (or even moving your mouse past the clips) it will temporarily halt rendering/background processing.
    Maybe that is it?
    FCP Guru
    http://www.fcpguru.com
  • James Cude
    September 6, 2011 at 11:27 pm
    What’s your Background Render “Start After” delay set for in Playback Preferences? Generally speaking you shouldn’t have to manage it manually. It should do its thing automagically.
  • Don Scioli
    September 6, 2011 at 11:47 pm
    Prefs are set to auto background render with after 5 sec checked. It seems to stop if the clip in question is selected by not playing.
  • James Cude
    September 7, 2011 at 12:30 am
    Hmm- well like I said it should just return to background rendering without being touched. Of course any thing you do in the timeline will stop it. I generally keep my delay at 30 seconds. Then I know it won’t do anything while I’m actually working but will only kick in when I go onto something not editing related. Some folks turn it off entirely when it impacts performance too much. And remember you can always force a render with Control-R on a selection.
