Activity › Forums › Adobe Premiere Pro › why does my waveform say my blacks are below 0 IRE after I change the levels??/
  • why does my waveform say my blacks are below 0 IRE after I change the levels??/
    Posted by Tyler Smith on May 8, 2008 at 1:45 pm
    whether I adjust the levels or not, it keeps friggin reading less than 0 IRE on my Yc Waveform monitor….anyone?
    Tyler Smith replied 18 years, 4 months ago 3 Members · 13 Replies
  • 13 Replies
  • Jeff Brown
    May 8, 2008 at 2:15 pm
    What kind of waveform are you using? Software, hardware, analog, digital?
    -jeff
  • Tyler Smith
    May 8, 2008 at 2:17 pm
    i click the button on the top right of my program monitor (prem. pro cs3) and click on Yc Waveform…so digital?
  • Jeff Brown
    May 8, 2008 at 2:24 pm
    Ah– the built-in software WFM. Does it read less than zero if you turn off the checkbox for the “chroma” display? And if so, maybe you could post a screen shot.
    -jeff
  • Tyler Smith
    May 8, 2008 at 2:30 pm
    It does read below zero if i turn off the chroma, and with it on too….
  • Vince Becquiot
    May 8, 2008 at 4:10 pm
    Can you post a still ?
    So are you saying that raising the blacks doesn’t affect the WFM display ? Are there black bars or graphics or other tracks ?
    Vince
  • Tyler Smith
    May 8, 2008 at 4:21 pm
    here’s a frame grab….
    https://photos-g.ak.facebook.com/photos-ak-sf2p/v195/244/36/520195519/n520195519_1058366_1011.jpg
    I’ve adjusted the levels, taken off the levels filter, and still having a weird reading of less than 0IRE after I render out….during the tweaking of the levels i can set it to where i need it to be but once rendered it goes wonky.
    the only way I can get rid of this problem is to Check the box at the top of the waveform monitor that says “setup (7.5 IRE) in premiere pro cs3….but i don’t really get what this has to do with anything
  • Jeff Brown
    May 8, 2008 at 4:37 pm
    Ah– what I’d like to see is a still of the ‘scope showing the readout for that image. [nice shot, BTW]
    -jeff
  • Tyler Smith
    May 9, 2008 at 2:29 am
    k, i’ll see if i can grab that…..how do i export a still of the waveform?? just like exporting a frame of video if it’s on composite video?
  • Tyler Smith
    May 9, 2008 at 9:25 am
    here’s a frame grab pic from my cell phone….the line directly below the double line represents 0 IRE…..
    keep in mind I used the three-way color corrector to set the levels….i’ve used the “levels effect” but it automatically tells me that my levels are between 0 and 100 when I don’t even adjust the settings….which is really strange….
    https://photos-a.ak.facebook.com/photos-ak-sf2p/v256/244/36/520195519/n520195519_1191264_1456.jpg
  • Jeff Brown
    May 9, 2008 at 2:23 pm
    A screen grab would be clearer: Shift+Ctrl+PrtScrn (usually near the ‘break’ key), but—-
    I don’t see anything truly below zero, except the heavy line on the right; that presumably includes the sync pulse, which had better go to about -20 IRE or your signal is out of whack.
    So – I think you’re OK there.
    -jeff
