Activity Forums Adobe After Effects Why does my text look like crap?
  • Why does my text look like crap?
    Posted by Outis on May 18, 2006 at 12:18 am
    Why does the text I generate in Illustrator 11.0 (using Avenir font in this instance–but other fonts as well) then turn into outlines and import as a layered .ai file into After Effects 7.0 look like crap? I have gone through the help and ticked the appropriate boxes for creating a pdf when saving and made sure that that the AICB and Preserve Paths options are chosen in the preferences.
    Curves like terrible and aliased. Is there some secret to fixing this a bit. It is rather frustrating as I have not had the same problem importing logos generated in Illustrator to other programs.
    Thanks in advance for your help.
    Justin Productions replied 20 years, 4 months ago 7 Members · 9 Replies
  • 9 Replies
  • Zander
    May 18, 2006 at 1:46 am
    ok several questions need to be answered
    what size was your text?
    what format are you using?
    is it interlaced?
    Aaron Zander
    student editor at brooks institute of photography
    12″powermac g4 1.25gb ram, 1.5 GHZ macosx 10.4.6 1.3tb external space
    finalcut 5.0.4 adobe cs2 afterefects 7pro
    currently working on BombIt: World WIde Graffitit
  • Steve Roberts
    May 18, 2006 at 2:12 am
    Did you click the “continuous rasterization” button for each AI layer in the AE comp? It’s the little sunburst.
  • Justin Productions
    May 18, 2006 at 5:14 am
    We don’t say “crap” here, we say “not good”.
    Thx for understanding.
    Justin Productions
    Tangerin01@hotmail.com
    Adobe After Effects 6.0 Professional
  • Mylenium
    May 18, 2006 at 5:33 am
    [Justin Productions] “We don’t say “crap” here, we say “not good”.”
    *lol* Considering it’s not exactly “one of those bad words”, I don’t think it’s really a problem. If we keep this up for the sake of misunderstood politeness and respect, we’ll probably end up using George Orwell’s Newspeak and say “doubleplusungood”. ;o)
    Mylenium
    [Pour Myl
  • Ron Lindeboom
    May 18, 2006 at 1:52 pm
    How will the flowers grow with no manure around? Chemical fertilizers may be cleaner but they just don’t hold a candle to a nice shovel of crap, so sez this ole farmboy. ;^P
    There are few words that can’t be used here and crap isn’t one of them.
    :o)
    A smiling as now thoroughly caffeinated,
    Ron Lindeboom
  • Tim Kurkoski
    May 18, 2006 at 4:49 pm
    Another tip- if you have your comp zoom set to “Fit”, your zoom may end up at a fractional value, which can cause issues with vector art. Change your zoom to 100% to get a true preview and it should look smoother.
  • Outis
    May 18, 2006 at 10:24 pm
    Thanks very much for the suggestions. I did notice it looked worse in the fractional views of fit. But the problem still occurs on the curves of the letters.
    I turned on the continuous rasterization and while it worked on straight lines, for the curves it got worse.
    If anyone out there has some other ideas, please let me know. This could also be a problem on the illustrator end, but am I wrong in thinking that many designers create their logos in Illustrator then import them into After Effects?
    As for the language issue, I suppose I shall refrain from comment, and merely humbly apologize to those that I offended.
  • Steve Roberts
    May 18, 2006 at 10:32 pm
    You really meant “carp”, right? It was a typo. 😉
    Anyway, could you send me the Illustrator file and a screengrab of the problem so I can check it out?
    … to: ads (aht) reidroberts (daht) (calm).
    May 18, 2006 at 11:30 pm
    Hey, I was just pointing out 🙂
    Okay-okay 😛
    Justin Productions
