Activity Forums Adobe After Effects Expressions Why does my script makes After Effects crash?
  • Why does my script makes After Effects crash?
    Posted by Otávio Nascimento on December 10, 2022 at 10:31 pm
    I made a script UI with a ‘edit text’ and a button. It apply to selected layers a effect that is inside the ‘edit text’. But when typing the effect wrong and using the button to apply, After Effects freezes. What can I do to make After Effects not crash when trying to apply an effect that doesn’t exist?
    function addEffect(findString)
    if (myFindString == “”) {
    return;
    var curItem = app.project.activeItem.selectedLayers;
    for (i=0; i
    Otávio Nascimento replied 3 years, 9 months ago 2 Members · 3 Replies
  • Otávio Nascimento
    December 11, 2022 at 12:48 am
    function addEffect(myFindString)
    if (myFindString == "") {
    return;
    for (i=0; i<curItem.length; i++){
    var layerI = curItem[i].property("ADBE Effect Parade");
    layerI.addProperty(myFindString);
  • Dan Ebberts
    December 11, 2022 at 12:52 am
    You could capture the error using try/catch, like this example:
    var myLayer = app.project.activeItem.layer(1);
    var myEffect = "xxxx";
    try{
    myLayer.property("Effects").addProperty(myEffect);
    }catch(err){
    alert('"' + myEffect + '" is not a valid effect name.');
  • Otávio Nascimento
    December 12, 2022 at 8:34 pm
    Thank you, thats what I needed.
