Activity Forums Adobe After Effects Why does my composition disappear in custom view!?
  • Why does my composition disappear in custom view!?
    Posted by Richard Arkinstall on September 2, 2011 at 10:03 am
    Hi, I have got 3 pre composed sequences that I am moving between. I have staggered these. The first one can been seen in custom views then the 2nd one appear but when the first comp clip ends the 2nd one disappears too when it should stay on!?
    Any ideas as to why this is happening!?
    I have checked the precomposed sequences for anything that isn’t 3D and removed any adjustment layers etc.
    Cheers for the help in advance…its making my work take much longer!
    Brian Charles replied 15 years ago 2 Members · 5 Replies
  • Brian Charles
    September 2, 2011 at 1:41 pm
    Can you provide a screen shot of what you’re seeing?
    Its difficult to understand from the description you provided.
  • Richard Arkinstall
    September 2, 2011 at 2:42 pm
    Hope that helps
  • Brian Charles
    September 2, 2011 at 2:50 pm
    Does Scenario 3 have layers positioned outside the camera’s angle of view?
    September 2, 2011 at 3:00 pm
    No they are all within that view….the 2nd scenario is actually directly below the 1st so its a little strange…
    I have actually moved the 2nd scenario along to the left so it comes on earlier and it stays on till that same point and disappears
  • Brian Charles
    September 2, 2011 at 4:47 pm
    What do you see in the Active Camera View?
