Activity Forums Adobe After Effects Why does my camera keep flipping around?
  • Why does my camera keep flipping around?
    Posted by Mark Pybus on June 19, 2007 at 7:05 pm
    hello there,
    I’m trying to rapidly zoom in and then back out, however, my camera keeps flipping around and facing the other way when I start the move back out.
    I’m sure I’m missing something quite simple, but I can’t for the life of me figure it out.
    Cooper Epps replied 9 years, 6 months ago 5 Members · 5 Replies
  • Andrew Kramer
    June 19, 2007 at 7:12 pm
    Try moviing the camera Point of Interest further away. You may be getting too close and the camera is turning its head.
    You also might try using a 3d null to controll the camera’s movement.
    Best,
    Andrew Kramer
  • Steve Roberts
    June 19, 2007 at 7:23 pm
    Or switch off layer>transform>auto-orient.
  • Brian Charles
    June 19, 2007 at 7:31 pm
    Simplest method to control the point of interest with a Null Object. That way you can control what the camera is looking at in the Active camera view.
    Create a Null Object, make it 3D, reveal the position for the Null, reveal the Point of Interest for the Camera and alt+click (Macintosh; Option + Click) on the Point of interest and drag the pick whip to the Null position.
    Now you can place the null where you want the camera to look.
  • Mark Pybus
    June 19, 2007 at 7:41 pm
    Fantastic! The null did the trick.
    Thanks again.
  • Cooper Epps
    January 30, 2017 at 5:15 pm
    Turning off auto-orient worked perfectly. Thanks so much!!
