Activity › Forums › Adobe After Effects › Why does IMAGEREADY slow down your animations?
  • Why does IMAGEREADY slow down your animations?
    Posted by Daniel Haskett on July 31, 2006 at 3:46 pm
    Hi there
    Basically Ive just saved out an animation as a MOV file from after effects at 25fps and imported it into IMAGEREADY. Ive then saved it optimised as an animated gif, but when I play the gif, it is alot slower than the original animation, is there some setting I need to change?
    Thanks in advance!
    Dan
    Mylenium replied 20 years, 2 months ago 2 Members · 3 Replies
  • Mylenium
    July 31, 2006 at 5:55 pm
    25 fps? That’s completely crazy. Use 12 fps or 15 fps maximum. It’s impossible to create larger animated GIFs at that high framerates. Apart from that, GIFs work in jiffies (some fraction of a second) not actual frames. It’s a completely different concept. Make sure you remove redundant frames and adjust the display length of the remaining frames to get the best compression with minimum data.
    Mylenium
    [Pour Myl
  • Daniel Haskett
    July 31, 2006 at 6:05 pm
    Ok, but how exactly do I do that? I mean removing redundant frames?
    Here is the quicktime mov file ive got……
    https://www.danhaskett.co.uk/future%20forum/quicktimetest2.mov
    Here is the resulting animated gif……. https://www.danhaskett.co.uk/future%20forum/image-ready-animted-gif-2.gif
    What do I need to do the quicktime mov, do i do something in AE or IR?
    cheers and thanks for all ur help mylenium
    dan
  • Mylenium
    August 1, 2006 at 5:38 am
    You can delete and re-arrange frames in ImageReady’s timeline. You can also determine a duration for each image, so longer periods where nothing happens really only consist of one image. In your example this would be the phases whenever the little guy stops and does nothing. If it is an option, you could even split your banner into multiple small tiles and embed them in a HTML-table to assemble them again. This could decrease overall filesize even more. Of course it’s only an option if your client knows how to work with e-mail templates and you are able to set it up this way.
    Mylenium
    [Pour Myl
