Activity Forums Apple Final Cut Pro Why does FCPX stops when I try to copy and paste some clips?
  • Why does FCPX stops when I try to copy and paste some clips?
    Posted by Suan k. Seol on August 14, 2024 at 6:13 am
    First, I tried to copy some clips to another timeline in the same library.
    It showed the message, ‘you’re moving clips between libraries… etc.’ (don’t remember exact wording, I stopped the message.’
    When I clicked ok, FCPX stopped.
    I reopened, and tried to copy the clips at the end of the same timeline instead. It showed the same message with ‘between libraries…’. I didn’t even try to go to different timeline!
    Everytime I try to copy and paste some chunk of clips It would stop.
    What could this be?
    Doug Metz replied 2 years ago 2 Members · 3 Replies
  • Doug Metz
    August 16, 2024 at 4:10 pm
    Without seeing the full error, or a screen recording of the steps taken to achieve it, I’d suggest beginning by resetting the app’s preferences. From Apple:
    You can reset Final Cut Pro settings to their original values.
    • Press Option-Command while opening Final Cut Pro.
      Final Cut Pro resets the settings and adds a file named VideoAppDiagnostics-FinalCut to the desktop, containing a record of your previous settings.
  • Suan k. Seol
    August 19, 2024 at 6:35 am
    Thanks Doug,
    Tried resetting FCP by deleting preferences while opening.
    But same thing happens.. I don’t get the error message any more, which is pity.
  • Doug Metz
    August 20, 2024 at 10:08 pm
    Hm. Very strange.
    Okay, next thing I’d try is this:
    1. Reboot the machine
    2. Open the problem library in FCP
    3. Select the library itself in Final Cut’s browser, and relink all of the files/original media
    4. Re-test
