Why does devinci resolve Render Source only even after keying and grading?
My problem is i can see my dng sequence files keyed out nicely right,
ive graded it, edited everything but when i go to “Deliver > add to render > Start”, i get the correct cuts but no grading or keying.
Everything is fine before the start button.Ive started a fresh project and keyed the green screen out, rendered and it worked fine.
Initially i thought i was cache, or other threads mentioned something about source check box but im a desperate newbie and in need of some clear guidlines here so all help is gratefully received.
spec davinci 15, PC WIndows 10, gtx285, Core i7 6700, 16gb RAM, Nvidia Geforce GTC 970.
files, DNG Sequence files, 4k 25fps, RAWMoh N
