Activity › Forums › VEGAS Pro › Why does chromakeyer effect not get turned off when I deselected the chromakeyer in video fx?
Jeff David replied 8 years, 1 month ago 3 Members · 11 Replies
Jeff David
July 6, 2018 at 4:54 pmThank you for your responses. I’m tied up now but I’ll get you some better screen grabs in a little bit.
I shrunk the ones I already posted down – as I was afraid they would exceed the size limits. I can make them bigger and maybe do two separate uploads.
If you position your cursor to the right and left click on your screen and then do CTRL + you can enlarge the images. I’ll still try to post some better larger screen shots cause the images are somewhat blurry when enlarging them that way.
The top sg was meant to show that there is no fx activated – but given what you said – I will double check that and post a better screen grab. You might have hit the nail on the head. Also- thanks for the info on the bypass. I did not know about that so thanks for teaching me something new. I’ll definitely check that out and post back the results.
Lenovo quad core i7 16gb of ram, Windows 8.1 MS 13 64 bit Thumbnail is view out of the Olde North Church window where the signal lanterns were hung, as in, \”1 if by land 2 if by sea\” looking across the Charles River to the Charlestown Naval Yard where rebels awaited the signal April 18th, 1775.
