Activity Forums Apple Final Cut Pro Why does changing computers cause rerendering?
  • Why does changing computers cause rerendering?
    Posted by Tangier Clarke on January 1, 2016 at 4:33 pm
    Does anyone understand why FCP X renders again when I change computers. My understanding is that my managed library contains the media, the render files, etc. When I move from computer to computer (work, laptop, home computer) using an an FCP X library on an external and all versions of OS X and FCP X are all the same, the project I am working on and already rendered starts going through a rerender process.
    Tangier
    Brett Sherman replied 9 years, 11 months ago 4 Members · 5 Replies
  • John Rofrano
    January 1, 2016 at 6:05 pm
    [Tangier Clarke] “My understanding is that my managed library contains the media, the render files, etc. “
    Only if you set it up that way. Go to your Library Properties and make sure that the Cache is set to In Library.
    ~jr
    http://www.johnrofrano.com
    http://www.vasst.com
  • Tangier Clarke
    January 1, 2016 at 6:39 pm
    Yep. Had that. Have it all set to stay with the library.
    Tangier
  • Matt Whittemore
    October 17, 2016 at 8:43 pm
    Did you ever figure this out?
  • Tangier Clarke
    October 17, 2016 at 9:43 pm
    Haven’t figured it out nor gotten a response on this that answers the question.
  • Brett Sherman
    October 18, 2016 at 1:09 am
    I have had a similar problem with cache files stored on a server. The crazy thing is, it doesn’t always happen. Sometimes you open a project and everything is rendered. Other times you open it and it has to re-render everything. Other times it has to re-render some things.
    The best I could figure out is that it had something to do with permissions. It was far worse on projects I restored from a backup.
    Brett Sherman
    One Man Band (If it\’s video related I\’ll do it!)
    I work for an institution that probably does not want to be associated with my babblings here.
