Activity Forums Adobe After Effects Why Does AE keep going Mosaic everytime I move the bezier?
  • Why Does AE keep going Mosaic everytime I move the bezier?
    Posted by Max Jackson on November 7, 2012 at 8:51 pm
    Hi CC,
    Off and on AE CS6 keep going mosaic everytime I drag the bezier, sometimes but not always. Why does it keep doing that? It’s driving me nuts.
    Picture attached. Thanks for any info as to why it’s doing this.
    John Cuevas replied 13 years, 9 months ago 3 Members · 4 Replies
  • John Cuevas
    November 7, 2012 at 9:27 pm
    I believe you have adaptive resolution turned on. Below your comp window, the 2nd box past views, if you open it up it’s probably set to adaptive, turn it to off and AE should stop that behavior.
    I generally only use adaptive when I’m really pushing the GPU or CPU.
    Johnny Cuevas, Editor
    Thinkck.com
    “I have not failed 700 times. I have succeeded in proving that those 700 ways will not work. When I have eliminated the ways that will not work, I will find the way that will work.”
    —THOMAS EDISON on inventing the light bulb.
  • Max Jackson
    November 7, 2012 at 9:39 pm
    Ah! Thank you!!! This roto’s been driving me crazy.
  • Darby Edelen
    November 15, 2012 at 2:39 am
    [Max Jackson] “Ah! Thank you!!! This roto’s been driving me crazy.”
    If you’re doing roto work and don’t want the adaptive resolution to kick in you could turn off “Live Update” instead of turning adaptive resolution off. The difference would be that the comp won’t re-render (or update) until you let go of your mouse. Might be easier to make fine adjustments to your mask path without waiting for the full quality preview to render.
    Note that this switch is one of the major “gotchas” in AE in that if you accidentally turn it on or forget that you turned it on it can be a pain to remember to turn it off 🙂
    Check it out in the Help.
    Darby Edelen
  • John Cuevas
    December 6, 2012 at 12:33 pm
    Glad I was able to help.
    Thinkck.com
