Activity Forums Adobe After Effects Why does a bezier curve sometimes paste as a mask, other times as keyframes?
  • Why does a bezier curve sometimes paste as a mask, other times as keyframes?
    Posted by James Bachalo on June 3, 2011 at 11:29 am
    Hi
    Beginners question. Trying to apply a bezier path on the clipboard to the XY coordinates of a TrapcodeParticular Effect on a Solid.
    I select the ‘Position XY’ under ‘Emitter’, then paste my bezier curve. Sometimes I can get it to paste correctly as keyframes, but mostly I just end up creating a new mask.
    Puzzled…
    Eric Holzapfel replied 14 years, 11 months ago 3 Members · 2 Replies
  • Brian Charles
    June 3, 2011 at 3:41 pm
    If the layer is selected, pasting will produce a mask. If the position property is selected (in most cases) you will past a motion path.
    Select the XY coordinates in Particular an paste.
  • Eric Holzapfel
    October 11, 2011 at 2:14 am
    Hello,
    Do you mean “Select the XY coordinates in Particular an paste.” or
    Select the XY coordinates in Position and paste?
    I am having a similar challenge with layer coordinates and comp coordinates.
    I have created a mask path – which follows the coordinates I like (not sure if it is comp coordinates or
    layer coordinates!) When I copy this path, and paste it into the position of my object, a ball, the
    path (?) is offset from the place where I would like the path for the ball to be.
    I want the ball to follow several linear paths, from point a, to b, to c, to d, etc. I want the ball to
    stop at a point, wait, and then continue, following the next path to the next point.
    I have masks on a layer that I want the ball to follow. I have been trying to copy the mask a path at a time. As soon as I paste the second path into the position layer of the ball, it blows all the previous
    coordinates, and moves them all away from what I would like to be the origin.
    I must be missing something, as I see this done all the time in Apple Motion, and even After Effects.
    any ideas or tips on this??
    eric as “eholz1”
    Final Cut Pro, Adobe After Effects, Photoshop
