Activity Forums Adobe After Effects Why does 16×9 footage come in squashed?
  • Why does 16×9 footage come in squashed?
    Posted by Milton Hockman on February 14, 2006 at 5:26 pm
    I imported a 16×9 footage that I saved out from AVID. It comes in squashed. I have to put the clip in the timeline, and then adjust the height of the clip to make it look correct. Anyone know how I can eliminate this step?
    Al replied 20 years, 6 months ago 3 Members · 2 Replies
  • Steve Roberts
    February 14, 2006 at 5:47 pm
    You need to tell AE that the clip is widescreen. File>interpret footage>main. Select widescreen pixel aspect ratio. Hit OK, then drag the footage onto the new comp button at the bottom of the project window to make a comp with settings that match the footage.
  • Al
    February 14, 2006 at 6:04 pm
    then once you’ve done all that — at the bottom of the comp window you may need to hit the button with the little white square to make the comp see the right pixel aspect ratio
