Activity › Forums › Apple Final Cut Pro › Why do these video clips show up as green in the Event Browser and Timeline?
  • Why do these video clips show up as green in the Event Browser and Timeline?
    Posted by Ian Brown on November 12, 2012 at 10:46 am
    I converted a lot of VHS tapes to DV using both a Datavideo DAC 100 analogue to digital converter and my Canon HV20 camera’s A – D facility.
    All the videos play perfectly in QT Player 7 although for some reason 5 of the files have generic QT icons whilst the rest have normal poster frames.
    However, when imported into FCP X these 5 appear as green icons in the Event Browser and green in the Timeline.
    They do not play any video but the audio is OK.
    I cannot remember which videos were converted with the DataVideo or the Canon but a comparison of the files in VideoSpec shows no difference in formats etc.
    Any idea what the problem is and how to cure it?
    Incidentally, FCP X is only referencing these files.
    As they were so large (DV-PAL) I did not copy the files to the events but I can’t see that this should matter.
    Ian Brown replied 13 years, 10 months ago 5 Members · 10 Replies
  • 10 Replies
  • James Cude
    November 12, 2012 at 5:00 pm
    Post some inspector snapshots of the clips. FCPX supports a lot of formats but it’s quite possible to create a format that it doesn’t support, especially with older gear.
  • Ian Brown
    November 12, 2012 at 5:58 pm
    I have discovered a workaround.
    Open in QT 7 and select File>Save As
    This produces a new file that works perfectly in QT X and FCP X.
    Of course the question still exists as to why these 5 files are different from the rest when they were created in apparently the same way.
  • James Cude
    November 12, 2012 at 6:54 pm
    So… help us help you. Please post some screenshots of the inspector looking at those clips when they are green.
  • Ian Brown
    November 12, 2012 at 9:51 pm
    Here are the screenshots which I had intended to include with my first post . . . . but couldn’t figure out quickly how to do it.
    As mentioned above the problem has been negated but the cause of it is still unknown.
  • John Heagy
    November 12, 2012 at 10:01 pm
    Is it possible you captured them as .dv and not .mov?
  • Ian Brown
    November 12, 2012 at 10:15 pm
    My DataVideo converter and Canon HV20 are both set to capture DV PAL.
    They were used connected to my iMac running FCP 7 at the time.
    The only variation that I am aware of is that some of the 20 odd tapes were captured with the DataVideo and some with the Canon.
    It would be enticing to think that the 5 dodgy ones were captured with just one device and the rest with the other.
    I haven’t had the opportunity to test both devices to see if this is the case.
    However, the dodgy files are not really dodgy as they work perfectly with FCP 7 and QT 7 . . . . . its just that they throw a wobbly when used with their successors.
    They must also contain all the video and audio info otherwise Save As would not be able to make perfect working copies.
  • James Cude
    November 13, 2012 at 12:00 am
    Hmm- it sounds like the capture device is to blame here and guessing on the age of the thing I’m suspecting an update for FCP X compatibility is not too likely.
  • Nick Toth
    November 13, 2012 at 2:38 am
    This has been the case since 10.0.0
    I find old DV files that won’t open in FCP X and some that will. No obvious reason why. The “save as” using QT Pro will work or convert to ProRes. Fortunately for me I rarely work in SD anymore so it’s not a big deal. There are a number of ways to batch convert such as using legacy FCP or MPEG Streamclip.
  • Andy Neil
    November 13, 2012 at 5:38 pm
    [Nick Toth] “I find old DV files that won’t open in FCP X and some that will. No obvious reason why.”
    I can confirm this. I haven’t dug deep to figure out the reason, but some video captured even with FCP legacy using the DV/DVCPRO NTSC codec will show up as an audio only clip with no video. That’s what you were seeing. For some reason, X will not recognize the video track on the file.
    Your solution and Nick’s both work. I myself used Compressor to batch convert the files into the same codec, and solved the problem that way as well.
    As far as I know, it’s only an issue with DV footage, not with any other codec.
    Andy
    https://www.timesavertutorials.com
  • Ian Brown
    November 13, 2012 at 6:36 pm
    Although the problem arises with FCP X and QT X there is an obvious difference in the video files as you can see in my first screenshot.
    The “good” ones have a poster frame and the “bad” ones don’t.
    In an effort to track down the cause I captured some analogue PAL using my DataVideo 100 and FCP 7 but the results were perfect.
    If I get time tomorrow I will try the same using my Canon HV20 as a converter to see whether that is the culprit or not.
