Activity › Forums › Apple Final Cut Pro Legacy › Why do subtitles bounce on playback?
  • Why do subtitles bounce on playback?
    Posted by Noam Osband on April 4, 2014 at 3:51 am
    Sometimes, if I play with subtitles, when I play them back in the canvas, they might bounce around or seem to jump from one spot to the other.
    But when I export the sequence they are not doing that and instead they are static like they should be.
    Why does it get a bit janky on playback? It’s annoying cause I think there is a problem and then I need to export a small movie file to discover there is not.
    Thought?
    thanks in advance,
    noam
    Noam Osband replied 12 years, 5 months ago 2 Members · 2 Replies
  • Nick Meyers
    April 4, 2014 at 1:39 pm
    what subtitle generator are you using?
    i have noticed this with Text Up Pro.
    sometimes if the underlying clip has a motion effect, the sub jumps up a few lines.
    solution is to render.
    nick
  • Noam Osband
    April 5, 2014 at 6:01 am
    Yeah, I’m totally using that text generator.
    Good to know! Thanks for the quick and useful answer!
