Activity › Forums › Adobe Premiere Pro › Why do my premiere pro cs6 renders take so long?
Posted by Joey Sperber on January 21, 2013 at 4:17 amI have recently switched to premiere from fcp, but I have noticed that my renders are taking much longer. I was rendering a 3 minute clip and it took 2 hours. Also premiere has just been sow overall. Am I doing something wrong. I am working on a 2010 21.5 inch iMac, with a intel i3 processor and 16gb of ram.
Raymond Wolters replied 12 years, 3 months ago 10 Members · 18 Replies -
Joey Sperber
January 21, 2013 at 1:42 pmYes I do have the mercury renderer turned on. My computer meets all the system requirements for premiere pro
Tom Daigon
January 21, 2013 at 3:23 pmWhen you say render do you mean just rendering the timeline so you can play it OR do you mean export to a file when you have finished the project.
Rendering time varies depending on how many and what kind of effects you have assigned to the clips on the timeline.
Exporting involves rebuilding each frame to the output format you have chosen while also processing any effects.
Tom Daigon
PrP / After Effects Editor
http://www.hdshotsandcuts.com
https://www.youtube.com/watch?v=DxPrG3WUyz8
(Best viewed at 1080P and full screen)
HP Z820 Dual 2687
64GB ram
Dulce DQg2 16TB raid -
Tom Daigon
January 21, 2013 at 5:55 pmWhat CPU do you have? Do you have a Nvidia cuda card? How much ram do you have? These are important factors influencing Rendering Previews and Exporting times.
Tom Daigon
HP Z820 Dual 2687
64GB ram
Walter Soyka
January 21, 2013 at 6:06 pm[Joey Sperber] “I have recently switched to premiere from fcp, but I have noticed that my renders are taking much longer. I was rendering a 3 minute clip and it took 2 hours. Also premiere has just been sow overall. Am I doing something wrong. I am working on a 2010 21.5 inch iMac, with a intel i3 processor and 16gb of ram.”
Joey, you’ll have to give us a bit more information.
In addition to the questions Tom posed, I’d ask the following:
Please describe your footage (file type and compressor), your sequence settings, your storage, and when exporting, your export format and settings.
Please also describe your workflow (how you got the files in, what effects you’ve applied, what you’re trying to achieve overall).
Walter Soyka
Creative Cow Forum Host: Live & Stage Events -
Joey Sperber
January 21, 2013 at 6:30 pmI am working with dslr footage 1920 1080 24p footage. I put that directly from the camera into premiere pro. When I export I use a QuickTime format using h264.
Walter Soyka
January 21, 2013 at 6:40 pm[Joey Sperber] “I am working with dslr footage 1920 1080 24p footage.”
Ok.
[Joey Sperber] “I put that directly from the camera into premiere pro.”
Are you copying the card’s contents onto your hard drive first, then importing into Pr via the Media Browser, or you trying to edit off the card while it’s still loaded in the camera?
What else are you doing to the footage? Any effects?
[Joey Sperber] “When I export I use a QuickTime format using h264.”
Consider using the H.264 presets instead of QuickTime with H.264. The encoders are significantly faster and higher-quality, and the resulting .MP4 files play beautifully on both Macs, PCs, and the web.
Walter Soyka
Joey Sperber
January 21, 2013 at 6:53 pmI do copy the contents of the card to my hard drive first and then import them via media browser. The only effects I applied was brightness and contrast and unsharp mask
Martin Rose
January 21, 2013 at 10:04 pmTake off the unsharp mask and then see how long it takes to export.
Martin
Joey Sperber
January 21, 2013 at 11:00 pmI’m not sure extactly what defragment means I am working on a mac platform
