Activity Forums VEGAS Pro Why do my online clips look soooo bad?
  • John Rofrano
    April 18, 2010 at 8:04 pm
    The video is stuttering because it can’t buffer fast enough. If you watch the play head you’ll see it is catching up to the download bar and then waiting for more video to download. How high a bit-rate did you use? Try lowering it. If WMV plays smooth, try using the same bit-rate you used for WMV. Also which MP4 encoder did you use? MainConcept or Sony? I use the Sony AVC encoder for own work and am very happy with it.
    ~jr
    http://www.johnrofrano.com
    http://www.vasst.com
