Activity › Forums › Apple Final Cut Pro Legacy › Why do I need to re-render using Edit to Tape?
Walter Biscardi replied 20 years, 2 months ago 9 Members · 11 Replies
Walter Biscardi
July 11, 2006 at 6:08 pm[redexit] “Walter, Render setting are all ticked in both selection and render all
I can usually work through most problems on FCP but this has got me stumped big time.”
Then something is wrong with the way you have the system set up to edit to tape. Either the output setting is different than your Sequence Settings or something along those lines. If you have rendered everything, FCP does not render at all when you Edit to Tape.
Walter Biscardi, Jr.
https://www.biscardicreative.com“I reject your reality and substitute my own!” – Adam Savage, Mythbusters
