Activity › Forums › Apple Final Cut Pro Legacy › Why do I have to render uncompressed 10 bit with a cc filter, where is the real time?
Posted by Ryanservant on June 30, 2006 at 2:16 pmI thought at one point I had real time color correction with working with uncompressed 10 bit HD. Now I have to render both cross dissolves and the three way cc filter…..can someone tell me what setting I have messed up?
thanks
Ryan
G5
xserve 2.5 TB
FCP HD
2 gigs ram
Used to be Kona Hd…Now its Decklink HD proRyan Servant
AirSeaLand Productions
http://www.airsealand.com
718-626-2646Ryanservant replied 20 years, 2 months ago 4 Members · 9 Replies -
Walter Biscardi
June 30, 2006 at 2:18 pmuncompressed 10bit HD? No I don’t think anything is realtime yet there.
Walter Biscardi, Jr.
https://www.biscardicreative.com“I reject your reality and substitute my own!” – Adam Savage, Mythbusters
Ryanservant
June 30, 2006 at 2:46 pmBut it is with 8?
G5
xserve 2.5 TB
FCP HD
2 gigs ram
718-626-2646 -
Walter Biscardi
June 30, 2006 at 3:10 pm[ryanservant] “But it is with 8?”
It’s been a while since I’ve done 8bit uncompressed HD, but I’m pretty sure transitions were RT with my Kona 2 / Med
Jeremy Garchow
June 30, 2006 at 4:01 pm8 bit should have more rt depending on frame rate and frame size (you should be getting some with 720p24). Also, it will depend on how fast your raid is.
Jeremy
Aaron Neitz
June 30, 2006 at 4:22 pmHere’s a little trick we use. 10 bit HD @ 1080, drop it into an 8 bit HD timeline, you get your basic CC and dissolves, and then you can switch it back to 10 bit and do a full quality render overnight.
Ryanservant
June 30, 2006 at 4:56 pmIf I drop 10bit hd into a 8 bit timeline don’t I have to render ti anyway because it doesn’t make the sequence settings?
G5
xserve 2.5 TB
FCP HD
2 gigs ram
718-626-2646 -
Aaron Neitz
June 30, 2006 at 5:46 pmNaw, it transcodes the 10 bit as 8 bit. Like rounding down on the fly.
Ryanservant
June 30, 2006 at 6:35 pmthanks I will try that right now
G5
xserve 2.5 TB
FCP HD
2 gigs ram
718-626-2646 -
Ryanservant
July 5, 2006 at 9:36 pmCharlie,
When i drop my stuff into a 10bit i get the nice pretty orange real time bar thing on my timeline. My play back is very stuutery and freezes like crazy….Do you think this is a ram issue or something? I think i only have 1.5 gb. I am just used to rendering overnight but I need to render about an hour and a half of cc filters and that is going to kick my butt.Ryan
G5
xserve 2.5 TB
FCP HD
2 gigs ram
718-626-2646
